Error: insufficient catalogue size
Old   January 7, 2005, 00:31
Default Error: insufficient catalogue size
Anurag
Dear All,
run in solver terminated with following errors
insufficient catalogue size. current catalogue size = 20000
details of error: error detected by routine MAKDIR
CDRNAM = /FLOW/GETVAR
CRESTL = FCAT
Action required: increase the file catalogue size (how ?)
i am doing a transient simulation of anisotropic porous media. start of the run was ok. error occured after writting three transient files.
I dont know anything about this error. Any help would be appreciated. thanks in advance.
Old   January 7, 2005, 10:01
Default Re: Error: insufficient catalogue size
Juan Carlos
Dear Anurag,
If you are using the command line to start the solver, you can do as follows:
cfx5solve -size-mms 1.2 -def ....
where the 1.2 will multiply the estimated catalogue size from the solver.
If you are on the Solver Manager GUI, go to the Solver tab in the Define Run panel and add -size-mms 1.2 to the Solver Arguments entry..
I am just guessing that 20% will be enough..
Good luck, Juan Carlos
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 04:01
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 15:37
