FSI - rotating domain CFX and mechanical
Old   October 19, 2018, 10:29
Unhappy FSI - rotating domain CFX and mechanical
Moni
Monimo is on a distinguished road
Hey there,
In the area of FSI I am a very, very beginner and hope somebody can help me
I am trying to set up a bidirectional Fluid Structure Interaction between a wind turbine blade and the outer domain, using rotational and linear velocity. I use a 120° section of the complete turbine (cylindric domain).
Here is the general outline
https://imgur.com/a/DMtK1UL
Now I want to create a set up, where I can simulate the rotation of 0,2 rad/second of the wind turbine and the inlet velocity of fluid domain with 10 m/s.
Here is my coupling
https://imgur.com/Z9dDCip
I am not sure about the areas, where I have to insert the velocitys. Of course I have to insert the normal velocity of stream in CFX, but for the rotation:
- Do I have to give in mechanical the radial velocity for my blade
- Do I have to use the rotating domain in CFX (than for all parts - think so?!)
- Or do I have to change both with the same value?
I am a little confused. Hope somebody can help me!
I Use Ansys 18.1 academic version.
Maybe there is also somebody, who can tell me, how I can create the output of the normal vector of the surface elements.
Greetings Monika
Monimo is offline   Reply With Quote
Old   October 19, 2018, 22:09
It appears you are quite new to CFX, so I recommend not working on the FSI work quite yet. First I recommend you do the CFX tutorials, especially the ones on rotating machinery, fsi and blade flutter. These are available on the ANSYS Customer webpage.
By the way, blade flutter is an alternate approach to this which may work better in your case. That's why you should get a background in blade flutter, fsi and rotating machinery before proceeding so you know what approach will work best.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   October 20, 2018, 09:49
Moni
First of all thank your for reply.
I have done steady state calculations but no FSI until now. So yes, I am beginner, as I already mentioned (I am still student, too).
Unfortunately I have to do this, its no question of will.
I am familiar with the FSI tutorial for the oscillating plate, and know, that tutorials about blade flutter in turbo mashinery are available.
But my colleagues, superiors (and I) act on the assumtion, that the flutter of turbo mashinery has as a cascade flutter an other physical background than airfoils in wind turbines and planes with the bending-torsion flutter. So their assumtion is, that the Transient Blade Row Modus of CFX ist not unimpeachable usefull for this task.
But I will go through the mentioned tutorials again
aeroelasticity, cfx; mechanical, fsi, wind turbine, wind turbine blade
1-Way FSI CFX to Mechanical - Imported loads (pressure/forces) not matching? MElsawy CFX 9 February 2, 2022 02:50
2 way FSI (CFX e Mechanical Transient) billoable Mesh Generation & Pre-Processing 2 October 6, 2016 05:43
[ICEM] 2 way FSI, CFX + Mechanical + ICEM, Remesh, Deformation due to fluid flow binoyjjohn ANSYS Meshing & Geometry 8 June 25, 2014 10:00
convergenceof natural convection prob. in cfx cpkewat CFX 15 January 31, 2014 07:29
Problem with gravity and rotating domain i.e. Rotor-Stator CFX Brendan CFX 0 September 2, 2013 04:58
