momentum source: continuity problems
Old   December 16, 2004, 11:08
Default momentum source: continuity problems
Johannes Radke
I am using cfx5.6 and I am quite unexperienced in cfd.
I tried to apply a general momentum source to simulate an anisotropic flow resistance in a single-phase flow. The geometry is cubical. The flow goes straight through the cube (z-Direction), the walls have fee-slip. For the source I used the nonlinear expression (At first only one direction for testing purpose):
GMSz=-const*abs(w)^0.8*w
Everything worked fine and the solution converged. My problem is, that the velocity is decreasing on the way through the cube without increase of the density. That means to me, that the momentum source (more a sink)is decreasing the mass during its way. I thought it would only decrease the momentum and lead to a higher pressure drop. Where is the mistake I make?
Thanks very much in advance
Johannes
Old   December 16, 2004, 11:28
Default Re: momentum source: continuity problems
NeedHelp
Dear Joahannes, I do not think you are making a mistake, as you can see I have a post further down, where I also have problems. In my case does the velocity though increase, and I have still not solved the problem. I think it is a free of charge extra facility in CFX5.6 . (I am happy you also have problems I was wondering if I was the only user that had this problem "or the only that have discovered it"). Not much help for you though Jens
Old   December 17, 2004, 05:21
Johannes Radke
Thanks for the response, Jens.
The effect of momentum source on AV flow and concentration october CFX 5 June 28, 2011 03:59
momentum source in half-cylindrical null objects Noel Phoenics 1 December 16, 2008 06:51
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Momentum Source in an accelerating frame fakir CFX 7 December 2, 2006 05:00
Momentum Source Convergence Doug CFX 1 June 16, 2006 06:54
