freezing multiphase
Old   December 14, 2004, 05:14
Default freezing multiphase
Mikhail
Hi all,
How i can solve this problem ? I have mix from 2 components. One component condensed gas, and the second a not condensed impurity. The impurity has less than 5 %. Condensed gas freezes on a cooled surface. How correctly to describe this process? I have applied some methods. 1 method I create a material with spasmodic change of viscosity and heat conductivity at temperature of sedimentation, using function step, for an impurity the separate material is created. In this case calculation enough not bad describes process of freezing of a component. However I not absolutely understand as in this case to take into account heat of phase change, and calculation is not so stable. 2 method I create a homogeneous binary mix (HBM) from two materials, the first material gas, the second material a firm body. I set heat of phase change in properties of gas. In this case I can not add a material describing an impurity. CFX writes " in one domain there should be only one HBM " However in this case I have received an icicle Probably someone knows other ways?
Picture available at 2 method http://www.cfdhelp.nm.ru/pict/cfx_krist1.png 1 method http://www.cfdhelp.nm.ru/pict/cfx_krist2.png
Best regards Michael
Difference of multicomponent and multiphase homogenous flows Luk_Fiz CFX 11 April 4, 2013 06:29
Use data from multiphase into DO radiation yashmash FLUENT 0 October 7, 2011 04:57
multiphase multicomponent physics ckleanth CFX 3 June 4, 2009 21:15
Freezing / Multiphase CFD Roger Yang CFX 0 November 30, 2006 10:54
Multiphase flow modeling Paul CFX 2 August 11, 2003 10:41
