Feedback from moving mesh
Old   December 5, 2004, 10:43
Default Feedback from moving mesh
Chien
Hi, Anyone know of the feedback problem you might expect in a moving mesh simulation? In particular, i would like to know how and what is causing it to occur. any help is appreciated.
ce
Old   December 5, 2004, 13:55
Default Re: Feedback from moving mesh
Rui
What feedback problem ?
Old   December 5, 2004, 14:11
Chien
As in when mesh is moved through displacement of the boundary, the fluctuation in flow field leads to convergence problem.
My domain has a boundary modelled as a free surface. The free surface is defined using the local pressure field. The change in shape of the free surface subsequently leads to change in local flow field.
I came over the "feedback" term in another CFX forum. Not sure if this term can correctly describe the problem I have. Just thought i ask..
Again, thanks for replying..
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
Dynamic Mesh moving interface help akash.iitb FLUENT 0 August 24, 2010 00:53
Moving Mesh Run problem - Scientific Linux G. SE Siemens 2 May 7, 2008 08:15
Moving (structured) mesh Jesper CFX 5 February 2, 2007 04:43
