Gas-solid flow+heat transfer+reaction
Old   November 26, 2004, 18:48
Default Gas-solid flow+heat transfer+reaction
Umesh
Hi all,
What is the capacity of CFX to model high solid flux gas-solid two-phase flow and solving that including heat transfer, species transfer, surface reactions. Also, is it possible to include particle size distribution for the solid phase.
thanks for your time
Umesh
Old   November 28, 2004, 17:48
Default Re: Gas-solid flow+heat transfer+reaction
You would have to discuss your intended model in some detail before it is possible know how easy or otherwise it would be to do your model. Any simulation with as many sub-models as you mention is bound to be very complicated! I suggest you talk to your local CFX rep.
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 01:58
heat transfer between solid and fluid Devy FLUENT 4 June 4, 2010 01:28
Heat Transfer boundary conditions for engine coolant flow simulation rajuks Main CFD Forum 0 February 15, 2010 10:04
heat transfer in two-phase flow Leonid Fromzel CFX 0 April 8, 2008 06:57
radiation heat transfer in gas turbine burner jarno FLUENT 0 December 27, 2005 08:34
