Hi all,
I recently create a tetra mesh with prism elements. When I check the mesh, it said the surface orientation is not okay but when I click on the "Fix", it should me a strange function and said it can't be fixed. A tsl script error pops up later. What can I do to fix this problem? If not solved this error, will that affect the simulation in CFX5.7? Thank you for your advice. Really don't know what to do right now.... From,Pete |
This error can affect simulation sometimes, especially when you have internal walls (we had such problems). To fix it you need switch on such families and use ReOrient Mesh->Reorient Consistent (in terms of new gui) for surface elements.
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 12:43 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
