Rotor Stator Simulation Power curve issue for different RPM |
October 10, 2018, 10:45 |
Rep Power: 14 |
Hi
I am using rotor-stator simulation with Frozen rotor and RANS computation with different RPM values and constant velocity. I wanted to calculate the power of the rotor and plot the power curve so that I can select the optimum RPM of the turbine. But unfortunately I am getting some crazy values like RPM Power 100 0.5686 W 200 0.5743 300 0.035 500 1.8 600 2.91 800 6.59 For RPM of 100 the tip speed is 4m/s since rotor diameter is 750mm So now the issue is I am not getting the parabolic curve where the Power reduces for increased RPM. So now my doubt is if I am making some mistake in this ? I have attached the power monitor for differert RPMs and for 300 the plot looks wierd as well, I havent changed anything here, except the rpm. I have attached the image of the power expression and the rotor domain setup |
October 10, 2018, 19:27 |
Rep Power: 144 |
Either you have a mistake in your modelling approach or your device's operating point is faster than 800rpm. Over to you to work out which.
October 11, 2018, 04:17 |
Rep Power: 14 |
The thing is its a quasi 2D model, that means its just one cell thickness of 2mm. And am running in steady RANS.
You mean my modelling approach for all RPM or just the 300 one ? What do you think about the power monitor plot for other rpms ? this small fluctuation is ok or ? |
October 11, 2018, 04:19 |
Rep Power: 14 |
Also I tried to increase the thickness in direction from 2mm to 4mm and 8mm and the power value increases for same RPM. I just wanted to see if its linear so that I can do the 2D simulation and then somehow interpolate for the 1m length in Z direction
October 11, 2018, 18:54 |
Rep Power: 144 |
I recommend you ignore this issue and deal with the accuracy issue discussed on the other thread first. Until you have some trust in your results there is no point in interpreting the results.
October 12, 2018, 04:53 |
Rep Power: 14 |
Exactly, first I want to find the optimum RPM for a speed of 10m/s
But as I increase the RPM the power value is also increasing and for 300rpm some strange effect is seen in the monitor plot. Where the power value goes down and then from 350 its going on increasing. Nothing has been changed. And till 2000rpm its going on increasing. And running at 2000 rpm is not at all a physical one I would say. Should I see changing the speed and running it ? |
October 12, 2018, 05:48 |
Rep Power: 144 |
This thread is now asking the same question as your other thread (Negative value for torque).
Please post further discussion on this topic on the other thread. We don't want multiple threads on the same topic.
Power calculation in centrifugal pump - CFD Post | Hazem_9 | ANSYS | 1 | May 11, 2017 15:22 |
Power curve issue | didane | Main CFD Forum | 6 | August 16, 2016 05:12 |
[ICEM] putting x number of points along a curve (tolerance issue) | darkEnergy | ANSYS Meshing & Geometry | 1 | March 10, 2013 01:10 |
Star CCM+ issue (VOF and Non newtonian power law) | Sam | Siemens | 3 | January 23, 2009 08:39 |
power curve of windmills with CFD | sayid | FLUENT | 2 | March 28, 2007 10:55 |
