W.N.
Rep Power: 9 ![]() |
I have a solved model with some results and another solved model with out this results.
How can I import those results from a solved model to another new solved model? To prevent repeat steps to get results. Can I obtain on results from solved model with out repeating steps ? |
Gert-Jan
Rep Power: 27 ![]() |
In principle, you can interpolate CFX-results on an empty def file. But on a half solved model....... What is a "solved model" in your opinion?
I would say that if you have a solved model, you have a result. In that case your question makes no sense. Can you elaborate? |
W.N.
Yes, I have a result. But I would not repeat steps to extract some of it at every case.
As example, I want to take results at 20 lines and 10 planes. So I want a method to do that with out draw line and plane at every solved model. So export those lines and plans from one model to another with out drawing it again. That is possible or not. I would that elaborate what I want to do. |
Gert-Jan
Do you mean in Post? Certainly you can do that. You can create all your lines and planes. Then save a state file and load a different case.
It is also possible to write script to save data to a file. You can loop over a line and export the data. Not really my cup of tea, but I think other people can help here. |
Save Results automatically by APDL Command | ansyxyz | ANSYS | 1 | June 5, 2018 08:16 |
OpenFOAM - Validation of Results | Ahmed | OpenFOAM Running, Solving & CFD | 10 | May 13, 2018 18:28 |
CFD results not close to experimental results | cider | STAR-CCM+ | 0 | July 8, 2013 07:53 |
Creating a tool to interpolate results | Luis Batista | OpenFOAM Running, Solving & CFD | 2 | April 11, 2013 08:15 |
Different Results from Fluent 5.5 and Fluent 6.0 | Rajeev Kumar Singh | FLUENT | 6 | December 19, 2010 11:33 |
