CFX heat transfer not working
Old   October 8, 2018, 08:41
Angry CFX heat transfer not working
Israel
shai007 is on a distinguished road
  1. I'm trying to do simple transient simulation of cooling copper tube with initial temperature of 100 C with water @20 degree that flowing inside the tube.
  2. The result not making any sense
  3. At final time the tube and water are at temperature of 20 C
  4. The dimensions of the copper tube is D1=30, D2=20, L =150
  5. The water velocity is 50 mm/s
  6. At inlet the temperature is 20 C
  7. No heat flow to the tube from the outside (adiabatic)
  8. Total time 100 s
  9. Ansys version is 19.2
  10. Can any one check my files
  11. https://drive.google.com/open?id=1dI...iKi2mg0jEiz6Da
  12. Or tell me whats wrong
  13. Or make the simple simulation and sent me
Many Thanks
shai007 is offline   Reply With Quote
Old   October 8, 2018, 08:55
urosgrivc
urosgrivc is on a distinguished road
Did you make all the needed interfaces and turned on heat transfer in the second tab in the interface settings?
You need to specify fluid-solid connections otherwise these are not connected
(..later in time)
Ok I see you have made connections
Outlet could be just pressure opening
And I am not sure jet why there is no trn.files created
(..later in time)
Ok it is working now
I have decreased the mesh size from 4mm to 2mm as it was really coarse
It would be good to add some inflation layers on the fluid walls
I have merged both bodies into one part to obtain a conformal mesh at the interface
Changed the outlet to opening
Initialize the velocity of water to 50mm/s in the correct direction
I have set solid timescale factor to 100
urosgrivc is offline   Reply With Quote
Old   October 10, 2018, 10:37
Default Initial temperature of the copper pipe
Israel
I made the changes that you suggested
and it seem that the initial condition of the pipe isn't set, i.e the pipe start at final temperature of the water 20 C, and not in it initial temperature 90 C
Old   October 10, 2018, 19:25
Setting initial conditions is very basic stuff. Have a look at the CFX tutorials for how to set up initial conditions.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
cfx, heat tranfer, tube
How does CFX treat an opening when heat transfer is modelled? JuPa CFX 2 September 9, 2014 06:34
CFX conjugate heat transfer problems dingsheng1206 CFX 7 February 13, 2014 14:29
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
CFX wall heat transfer coefficient mactech001 CFX 1 January 5, 2010 22:33
