Saif Ul Malook
Rep Power: 7 ![]() |
I am doing a problem similar to the steam jet tutorial example but at higher temperatures (640K instead of 373) and a higher proportion of air in the inlet flow. I have tried using Steam5 from the IAPWS library but I continue to get a divergence in something called "newton method". I solved that problem by replacing the steams for water ideal and water liquid and creating a homogenous binary mixture with Antoine Equation used for saturation curve.
I also used a common reference state (P,T) for the specific enthalpy and entropy values for both the states. However, a variable in the tutorial called "SatLHeat" which is the latent heat of vaporization gets an error that it could not be solved. the variable is defined as "Gas.Water Ideal Gas.enthsaturation - Liquid.Water.enthsaturation". If someone can guide me about this. please ask me if there's more that I need to explain. |
HeatSource BC to the whole region in chtMultiRegionHeater | xsa | OpenFOAM Running, Solving & CFD | 3 | November 7, 2016 05:07 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 06:37 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 03:34 |
Error while running rhoPisoFoam.. | nileshjrane | OpenFOAM Running, Solving & CFD | 8 | August 26, 2010 12:50 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
