how to make it rotate?
Old   November 14, 2004, 06:24
Default how to make it rotate?
marco
For CFX 5.5, i want to make some blades to rotate inside a blender, but i dun know how to do.can any one help me? thanks
Old   November 19, 2004, 12:14
Default Re: how to make it rotate?
Ian
It's a bit too complicated to fully describe in an on-line forum, but the basic process is to create 2 grids; 1 for the blades and one for the tank. These 2 grids are imported into Build and a MFR (Multiple Frame of Reference) analysis is set up in the domains form. I think this was available in 5.5? Refer to MFR in the help menu for more details.
For that matter 5.5 is about 3 years out of date (5.7 is the current release) and I'm surprissed that your Build license still works. I would suggest contacing tech support but I'm pretty sure 5.5 is no longer supported.
Old   November 19, 2004, 13:14
marco
thanks for you help first
but can you tell me how to import two grids at the same time?
Old   November 19, 2004, 14:15
Ian
It's been a couple of years, but if I remember right and you're creating the grids in Build then you need to start each database as "meshing only" mode (in the initialization panel) to create the 2 grids. Once they are done you create a 3rd database (I can't remember what mode options are available, but if there's something that refers to no meshing, or import grids then that's what you want) and import the 2 grids.
Hope that this helps.
Why can't I make the boundaries periodic? Alina FLUENT 5 April 12, 2012 15:06
how to make grid in gambit? pankaj verna FLUENT 2 May 4, 2007 10:36
CFX 5.5 how to make it rotate? Marco CFX 1 November 11, 2004 17:35
nEED Need Your Help to make a PACKAGE CODE Ghassem Main CFD Forum 0 February 24, 2000 13:38
[Q]How to make MPEGs with CFD datas??? Bum-Seok Hyun Main CFD Forum 4 February 16, 2000 19:59
