Meshing problems icem cfd 5.0
Old   November 12, 2004, 16:41
Default Meshing problems icem cfd 5.0
Alex
Hello all, here is my problem:
I want to mesh a gap with 5 µm width and 25 mm length. I want 6 nodes on the 5 µm edge and 25000 nodes on the edge with 25 mm length. When I set these values to the edges and pre-mesh, I only get the 5 µm edge meshed. The "long" edge isn't meshed until I reduce the nodes below 1000. There I get the mesh. What is the problem, respectively how can I fix it? Thanks in advance, Alex
Old   November 13, 2004, 13:53
Default Re: Meshing problems icem cfd 5.0
deLuther
Yes, ICEM does not support edge division more than 1000. The only way is to split your block 25 times...
Old   November 14, 2004, 17:35
It is very difficult to generate a good mesh on geometries with such a huge range of length scales - especially with tet elements. These type of geometries are generally much better meshed with hex elements as these elements can handle higher aspect ratioes. Are you using ICEM-HEXA?
Old   November 15, 2004, 06:07
deLuther
Glenn, It is problem in HEXA when you can not specify edge division more than 1000...
Meshing in ICEM CFD rahulsng ANSYS 2 March 4, 2015 05:03
[ANSYS Meshing] Icem cfd - hexa meshing arunkumarnd ANSYS Meshing & Geometry 9 April 12, 2012 06:47
[ICEM] (ICEM CFD) meshing over a cylinder vmlxb6 ANSYS Meshing & Geometry 6 August 11, 2010 15:37
[ICEM] Need help in ICEM CFD Mapped Meshing falconf16 ANSYS Meshing & Geometry 3 February 19, 2010 15:21
ICEM CFD Meshing James ANSYS Meshing & Geometry 0 March 4, 2009 09:41
