ICEM 5.0 - double meshing
Old   November 7, 2004, 07:09
Default ICEM 5.0 - double meshing
Joan
Hi everyone. I tried to draw a concentric cylinder. The inner tube has inlet/outlet on the side and another pair in the midway. But everytime, i have double meshing (i am using hexa mesh). if i do the blockings and o-grids for the inner tube first and then the outer tube, the inlet/outlet on the side will have double meshing. if i do the other way round, and put the central block into VOFRON, the innertube will have double meshing. do anyone know how i can avoid double meshing? and how i can mesh this properly? thanks a lot. joan
Continuing User Defined Real Gas Model issues aeroman FLUENT 6 April 8, 2016 04:34
New densitybased solver AeroFoam giulio_romanelli OpenFOAM Running, Solving & CFD 48 January 15, 2016 09:20
Parallel User Defined Real Gas Model aeroman FLUENT 4 July 1, 2015 07:09
Missing math.h header Travis FLUENT 4 January 15, 2009 12:48
REAL GAS UDF brian FLUENT 6 September 11, 2006 09:23
