October 1, 2018, 09:58 |
Flow of gas and water in concentric pipes
Rep Power: 14 |
Hi All
I am trying to simulate a flow inside a circular channel with a needle which is having a wall thickness of 1mm and inside the needle gas is flowing and outside, water is flowing inside the channel. This water flow velocity will help to create the bubble from the needle and detach the bubble from the needle. But due to this thickness of the wall, My timestep is very less since I have this small wall thickness which controls the dt. So now my doubt is, whether its possible to have a small thin wall so that I can avoid the mesh size constraint. I need an internal wall for gas flow and external wall for water flow. I have attached an image. |
October 2, 2018, 05:41 |
urosgrivc
Rep Power: 12 |
Your timestep would be very small despite that thin wall,
because of the physics, you are resolving. |
October 2, 2018, 05:50 |
Rep Power: 14 |
Yeah true, but this small thickness is 1mm is just a sample, I have one needle of thickness 0.002mm so this will be controlled by the thickness of the mesh in that region, so I was thinking if there is any possiblity to have a thin wall of zero thickness so that I can give mesh on both sides.
October 2, 2018, 08:51 |
Gert-Jan
Rep Power: 28 |
This is a geometry/mesh problem, so better ask this in the meshing & geometry forum.
Nevertheless, sure this is possible. In ICEM, you can have an internal wall. When set as split wall, you will have a different mesh on both sides, allowing you to create different BC's in Pre. Not sure if it will help you in reducing time step........ |
October 2, 2018, 09:30 |
urosgrivc
Rep Power: 12 |
aha.. but if you can neglect the thickness of 0.002mm at the end you could probably bring your needle wall of small thickness to a point 0 at the end so it would be at a slight angle and the tip would not have thickness maybe
October 2, 2018, 09:44 |
Rep Power: 14 |
Oh yeah that is also possible in case of the needle geometry. but if its a micro pipe then its going to be hard.
October 2, 2018, 19:13 |
Rep Power: 144 |
I do CFD of MEMS devices and dimensions of a micron or two is common. Some of my simulations require time steps of 1e-10s due to the very small length dimensions and fast rate of the effects. So do not be afraid of using small time steps.
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 22:43 |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 06:37 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 02:27 |
error message | cuteapathy | CFX | 14 | March 20, 2012 07:45 |
