Problem with rotational mesh deformation: Part II
Old   November 3, 2004, 06:34
Default Problem with rotational mesh deformation: Part II
NymphadoraTonks
I'm getting no where with this problem so I have to ask for help again. I have modified my test case slightly to simplify it.
I busy playing with the mesh deformation functionality in CFX 5.7.
I've set up a simple test problem as follows: http://www.imagedump.com/index.cgi?pick=get&tp=145367
The origen of the coordinate system is in the exact centre of the fluid domain. The idea is for the flap to rotate around the coordinate system origen to present a varying obstruction to the flow.
I have named the cut out "flap" and specified its motion explicitly using CEL. In the Flap boundary condition mesh motion dialog I have set "Specified displacement" and used two CEL functions "XDisplacement" and "YDisplacement" for the X and Y displacements respectively.
I then defined these as follows:
AngleAmp = (30/360)*2*pi [rad] To = 1[s] Angle = AmpDeg*(t/To)[rad] XDisplacement = ((x*cos(Angle))-(y*sin(Angle)))-x YDisplacement = ((x*sin(Angle))+(y*cos(Angle)))-y
It's dead simple ... the flap is supposed to rotate 30* around the origen in 1 second.
The mesh outline at time 0: http://www.imagedump.com/index.cgi?pick=get&tp=145367
The mesh outline at time 1.0s: http://www.imagedump.com/index.cgi?pick=get&tp=145368
As you can see the rotation is correct i.e. 30* but the flap has "shrunk" down in size.
Any suggestions as to where I'm going wrong?!
TIA
Old   November 3, 2004, 08:21
Default Re: Problem with rotational mesh deformation: Part
NymphadoraTonks
Oh lord ... how could I have been so dense!
Nevermind I've spotted my mistake
Old   November 4, 2004, 04:05
Ben
hi tia, i 've got a quite similar problem with a rotating flap. can you tell me wether you made your mistake with the CEL- expressions or was there an other source for this "shrinking flap"
thanks in advance
Ben
[Other] engineFoam new mesh problem ayhan515 OpenFOAM Meshing & Mesh Conversion 5 August 10, 2015 09:45
A question on adaptive remeshing or mesh deformation for handling object motions daveatstyacht OpenFOAM 10 November 13, 2010 10:29
problem related to mesh naveen CFX 3 March 25, 2006 09:47
CFX 5.7 rotational mesh deformation? NymphadoraTonks CFX 7 October 11, 2004 19:35
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 11:09
