outlet boudary condition for a flow in the pipe |
October 28, 2004, 08:08 |
I would like to simulate the flow in a circular pipe with a turbine in the pipe. [ I did not model the streamline disturbance by the turbine, I model the turbine as the subdomain with a momentum sink] I specify the inlet boundary condition of the pipe as "Inlet" with a given x-component velocity. For an outlet boundary condition, I think I should specify "Outlet" with an x-component velocity as v2 = rho1*v1/rho2. This v2 comes from the continuity equation for 1D flow. However I saw that in the tutorial about "flow through a butterfly valve" and "flow in a catalytic converter" of CFX, they are all specified the zero relative pressure as the outlet boundary condition. 1. I was wondering about zero relative pressure that when do we use this boundary condition? Should I use it in my case? 2. In "flow in a catalytic converter", I note that it's emphasized that the outlet boundary condition must be static pressure, not average static pressure. Do anyone know why? Thank you very much.
Atit |
October 31, 2004, 14:11 |
Re: outlet boudary condition for a flow in the pip
In additon, when I set zero total pressure at the inlet of the pipe, what does it mean? When should we use this condition? Thank you.
Atit Koonsrisuk |
November 9, 2004, 18:43 |
all the boundary conditions and their meanings have been documented in the USER MANUAL. Please refer to them!!
regards!! |
Disturbed flow field at outlet boundary (Multiphase flow through pipe) | Michiel | CFX | 17 | April 21, 2010 11:14 |
VOF Outlet boundary condition in cfd - ace | JM | Main CFD Forum | 0 | December 15, 2006 09:07 |
Outlet boundary condition in channel flow solving with interFoam | liuzhw | OpenFOAM Running, Solving & CFD | 0 | November 29, 2005 22:07 |
Outlet Boudary Condition for Fully Developed Flow | Saad | Main CFD Forum | 5 | November 19, 2004 14:22 |
Outlet boundary condition for pulsatile flow | Timite | FLUENT | 0 | January 22, 2003 04:56 |
