Glass viscosity
Old   September 27, 2018, 10:13
Default Glass viscosity
Davide
marsa27 is on a distinguished road
I would like to simulate the glass forming with a VOF model. As the viscosity of the glass varies strongly with the temperature, I would know how to implement a viscosity law with the temperature in CFX Pre (I already have this relationship).
Thank you very much
marsa27 is offline   Reply With Quote
Old   September 27, 2018, 19:32
You simply define the viscosity as a function and put that in your material model. You can define the function with interpolation tables, CEL expressions or user fortran. For examples of how to do these things and how to modify material models look in the CFX tutorials.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   October 8, 2018, 11:22
Default Cel
Davide
So is it possible to set a CEL expression like a polynomial with the temperaure as variable for the viscosity material property?
Old   October 8, 2018, 12:00
Gert-Jan
Gert-Jan will become famous soon enough
Yes that is possible. I would recommend to limit temperature using min & max functions, to avoid unrealistic viscosities outside the range of applicability during the simulation.
Use the Evaluation-fucntion of CFX-Pre when setting up the expression. This allows you to check whether you get realistic values and do not make a typo.
Also, make sure you use enough digitis for your polynomocal coefficients a,b,c, etc. Round off errors can become large if you have a term like a*T^6
In other words: check, check, double check.
Gert-Jan is offline   Reply With Quote
Old   March 7, 2019, 20:13
Default Min max
Davide
Thank you, how can I limit the function? Can you write an sample?
Old   March 7, 2019, 20:14
Default Min function
Davide
Old   March 7, 2019, 22:16
Have a look in the CFX reference guide for functions available in CEL. Functions which can be used as limiters include step, if and max/min.
Old   March 8, 2019, 10:57
Gert-Jan
min(1e7[Pa s], max(1 [Pa s], function))
where function is your viscosity as function of whatever you want.
If you use one of the predefined viscosity functions like powerlow or Hershel-Bukly, min and max values for shear rate are available as well.
As Glenn mentioned, look for it in the manual.
Old   March 8, 2019, 11:08
Default Thank
Davide
Thank you very much.
If you use one of the predefined viscosity functions like powerlow or Hershel-Bulkly, min and max values for shear rate are available as well.
Dynamic viscosity and Kinematic viscosity asal FLUENT 7 September 3, 2019 02:25
Problem with divergence TDK FLUENT 13 December 14, 2018 07:00
driftFluxFoam viscosity model modification problem dleduc OpenFOAM Programming & Development 15 October 1, 2018 10:37
2D Glass Melt Simulation Setup marmz FLUENT 5 October 9, 2016 16:25
modelling solids viscosity in eulerian multiphase model derkaiser FLUENT 1 December 5, 2011 04:42
