October 19, 2004, 18:29 |
ANSYS Flotran for porous material
Does anybody knows how to use ANSYS flotran to model porous material by using fluid142? I put the permability into the model, but it seems the result did not change at all.
I saw a lot of people here using CFX to model porous material problem, is the theory for Flotran and CFX similar? Any comments are welcome! Thanks |
October 19, 2004, 19:39 |
Re: ANSYS Flotran for porous material
Jim:
Email me and I will send you an example. Cheers, Derrek |
October 20, 2004, 14:58 |
November 16, 2004, 20:01 |
I have computed the seepage field of a earth dam,but I use thermal anlysis,if you think this may be useful,I can send it to you
November 17, 2010, 06:06 |
Flotran
#5 | |
Ramadan
My email is ramawaad@gmail.com
I made simulation for fracture aquifer. groundwater water model. I want to used FLOTRAN141(2D). but I do not how to put the permeability. I expoler in material model in ANSYS-FLOTRAN I get thermal conductivity only no hydrualic conductivity. If you have Tutorial IN ANSYS GUI.Shell you send it? Quote:
December 9, 2011, 13:41 |
yasharif
Rep Power: 16 |
Dear Sun man
can you sen me your example file for earthen dam analysis ? I would like to look into it. I am working with Ansys 13 environment for earthen dam break . I am very new in this .my email address>yasharif@yahoo.com thanks sharif |
December 10, 2011, 06:58 |
Rep Power: 144 |
You might be modelling a dam break, but I doubt a flotran simulation will help you much. It is the old CFD solver which used to come with ANSYS FEA.
December 10, 2011, 07:10 |
Thnx, you are right
yasharif
Rep Power: 16 |
Thnx, you are right, I am modeling a dam break.
Do you have any step by step handout or sample problem that would help me to build up the model in ANSYS 13. I appreciate your help. Thank you very much. sharif |
December 11, 2011, 03:42 |
help needed
#9 | |
yasharif
Rep Power: 16 |
I am very new in ANSYS 13. Can you tell me the step by step procedure to compute seepage field of a earth dam ? I appreciate your help. Thank you . Sharif |
December 11, 2011, 18:59 |
#10 |
Rep Power: 144 |
The free surface flow over a bump tutorial is a good start.
This old post is all about flotran so will not be any use to you if you are using CFX - that's if the original authors are still alive. |
December 12, 2011, 00:10 |
Thnx
#11 |
yasharif
Rep Power: 16 |
Thank you very much dear friend.
Is there any tutorial on that so that would help me in defining the porous material like mixture of soils..? Thanx again |
December 12, 2011, 18:15 |
#12 |
Rep Power: 144 |
The catalytic converter example uses a porous material. I think you should go through the tutorials yourself and do the ones relevant to your model.
December 13, 2011, 00:02 |
Thnx
#13 |
yasharif
Rep Power: 16 |
sharif |
February 29, 2016, 07:31 |
Flow through a porous media
#14 | |
Rajendra Kumar
Rep Power: 10 |
February 29, 2016, 07:34 |
Flow through a porous media fluid flow
#15 | |
Rajendra Kumar
Rep Power: 10 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 09:56 |
Ansys FLOTRAN. Remeshing according velocity vectors or streamlines? | pablo--- | ANSYS | 2 | December 11, 2009 05:35 |
ANSYS FLOTRAN and CFX | Paul Atreides | Main CFD Forum | 0 | December 27, 2006 11:23 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 13:02 |
