WinXP CFX5.7 crash
Old   October 19, 2004, 13:49
Default WinXP CFX5.7 crash
Lorenz Seiler
I have several PCs I have to support running WinXP SP1 and CFX5.7. The specs are P4 2.8GH, 1Gb of RAM and a Hercules (ATI) 9800XT or Pro resp. One of them suddenly switches of while the solver is running, the other crasches with a blue screen. Other applications like CATIA R13SP5 run just fine. The rest of the computers with the same specs and installation run fine under CFX. Has anyone heard of such erratic problems, and where could the problem really be?
Old   October 19, 2004, 15:05
Default Re: WinXP CFX5.7 crash
Stevie Wonder
It could be the memory in one of your PCs. Why don't you run a memtest in your system. I'm almost sure that is not an OS problem.
Good luck, S. W.
Old   October 20, 2004, 01:41
Charles
Most likely a dodgy memory chip. CFD stresses memory more than most other applications. The fault can be difficult to find, but try swopping memory modules between machines.
Old   October 22, 2004, 00:52
Jeff
I had the same trouble with several PC's that would over heat. The solver stresses the CPU to 100% and requires the maximum airflow through the chassis. If the vents or fans get plugged up with dust over time, the chips can overheat and either shut down (black screen) or give the windows "blue screen of death".
Honest! I've had both of these occur. I opened the cases and the CPU fans were occluded to about 25% with dust. Once cleaned (with small hand vacuum) the CFX solver ran fine. Take a look. It's worth a try.
Jeff
Dragging Slice File = Crash cbritan OpenFOAM Bugs 3 January 6, 2011 04:58
Graphic/plotted monitors causing Fluent 12.0 to crash Autumn FLUENT 6 May 25, 2010 02:19
CFX5.7 to CFX5.6 Haferbrei CFX 1 December 7, 2004 17:07
CFX5.7 in Parallel Ogbeni CFX 1 December 6, 2004 12:19
CFX5.7 coal combustion and other reaction particle Leosding CFX 0 April 21, 2004 09:58
