Convective Heat Transfer - Heat Exchanger
Old   October 19, 2004, 01:36
Default Convective Heat Transfer - Heat Exchanger
Mark
Hi!
I tried to simulate a heat exchanger. Water is flowing in counter flow and is separated by a solid wall out of copper. One side has an inlet velocity of 1 m/s and an inlet temperature of 283K the other has a velocity of 10 m/s and an inlet temperature of 363K. After 140 iterations and a residual of 10e-5 CFX-Post shows a temperature from over 370K at the solid domain. That is much warmer than the inlet!!! Below you can find the command file. Another person than me had also a look at the boundary conditions and could not find any error. Although I modelled the heat exchanger very short (100mm), I do not believe that entrance effects are the reason for this!? Because of creating not to much cells, I modelled this problem as "2 dimensional" with only one cell in one coordinate direction and symmetry boundary conditions. Is there anybody with experiences in modelling convective heat transfer in CFX or knows where I can find some information or examples.
Thanks for any help,
Mark
FLOW: DOMAIN INTERFACE: Default 1
Boundary List1 = Default 1 Side Fluid1 Part 1
Boundary List2 = Default 1 Side Solid Part 2
Connection Type = Automatic
Interface Region List1 = FLUID1 External
Interface Region List2 = SOLID External B
Interface Type = Fluid Solid END DOMAIN INTERFACE: Default 2
Boundary List1 = Default 2 Side Fluid2 Part 1
Boundary List2 = Default 2 Side Solid Part 2
Interface Region List1 = FLUID2 External
Interface Region List2 = SOLID External A
Interface Type = Fluid Solid END DOMAIN: Fluid1
Coord Frame = Coord 0
Domain Type = Fluid
Fluids List = Water
Location = FLUID1
BOUNDARY: Default 1 Side Fluid1 Part 1
Boundary Type = INTERFACE
Interface Boundary = On
Location = FLUID1 External
BOUNDARY CONDITIONS:
HEAT TRANSFER:
Option = Conservative Interface Flux
END
WALL INFLUENCE ON FLOW:
Option = No Slip
END
END
END
BOUNDARY: Fluid1 Default
Boundary Type = WALL
Create Other Side = Off
Interface Boundary = Off
Location = WALL1
HEAT TRANSFER:
Option = Adiabatic
END
Option = Free Slip
END
END
END
BOUNDARY: In1
Boundary Type = INLET
Location = BOTTOM1
FLOW REGIME:
Option = Subsonic
END
HEAT TRANSFER:
Option = Static Temperature
Static Temperature = 10 [C]
END
MASS AND MOMENTUM:
Normal Speed = 1 [m s^-1]
Option = Normal Speed
END
END
END
BOUNDARY: Out1
Boundary Type = OUTLET
Location = TOP1
FLOW REGIME:
Option = Subsonic
END
MASS AND MOMENTUM:
Option = Average Static Pressure
Relative Pressure = 0 [Pa]
END
END
END
BOUNDARY: Symmetry
Boundary Type = SYMMETRY
Location = LEFT1,RIGHT1
END
DOMAIN MODELS:
BUOYANCY MODEL:
Option = Non Buoyant
END
DOMAIN MOTION:
Option = Stationary
END
REFERENCE PRESSURE:
Reference Pressure = 1 [atm]
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
HEAT TRANSFER MODEL:
Option = Thermal Energy
END
THERMAL RADIATION MODEL:
Option = None
END
TURBULENCE MODEL:
Option = Laminar
END
END END DOMAIN: Fluid2
Domain Type = Fluid
Fluids List = Water
Location = FLUID2
BOUNDARY: Default 2 Side Fluid2 Part 1
Location = FLUID2 External
HEAT TRANSFER:
END
Option = No Slip
END
END
END
BOUNDARY: Fluid2 Default
Location = WALL2
HEAT TRANSFER:
Option = Adiabatic
END
Option = Free Slip
END
END
END
BOUNDARY: In2
Location = TOP2
FLOW REGIME:
Option = Subsonic
END
HEAT TRANSFER:
Static Temperature = 90 [C]
END
MASS AND MOMENTUM:
Normal Speed = 10 [m s^-1]
END
END
END
BOUNDARY: Out2
Location = BOTTOM2
FLOW REGIME:
Option = Subsonic
END
MASS AND MOMENTUM:
END
END
END
BOUNDARY: Sym2
Location = LEFT2,RIGHT2
END
DOMAIN MODELS:
BUOYANCY MODEL:
END
DOMAIN MOTION:
Option = Stationary
END
REFERENCE PRESSURE:
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
END
Option = None
END
TURBULENCE MODEL:
Option = Laminar
END
END END DOMAIN: Solid
Domain Type = Solid
Location = SOLID
Solids List = Copper
BOUNDARY: Default 1 Side Solid Part 2
Location = SOLID External B
HEAT TRANSFER:
END
END
END
BOUNDARY: Default 2 Side Solid Part 2
Location = SOLID External A
HEAT TRANSFER:
END
END
END
BOUNDARY: Solid Default
Location = SOLIDBOTTOM,SOLIDTOP
HEAT TRANSFER:
Option = Adiabatic
END
END
END
BOUNDARY: SymSolid
Location = SOLIDLEFT,SOLIDRIGHT
END
DOMAIN MODELS:
DOMAIN MOTION:
Option = Stationary
END
END
INITIALISATION:
Option = Automatic
INITIAL CONDITIONS:
TEMPERATURE:
Option = Automatic with Value
END
END
END
SOLID MODELS:
END
Option = None
END
END END OUTPUT CONTROL:
RESULTS:
File Compression Level = Default
Option = Full
END END SIMULATION TYPE:
Option = Steady State END SOLUTION UNITS:
Angle Units = [rad]
Length Units = [m]
Mass Units = [kg]
Solid Angle Units = [sr]
Temperature Units = [K]
Time Units = [s] END SOLVER CONTROL:
ADVECTION SCHEME:
Option = High Resolution
END
CONVERGENCE CONTROL:
Length Scale Option = Conservative
Maximum Number of Iterations = 200
Solid Timescale Control = Auto Timescale
END
CONVERGENCE CRITERIA:
Residual Target = 0.00001
Residual Type = RMS
END
DYNAMIC MODEL CONTROL:
Global Dynamic Model Control = On
END END END
Old   October 19, 2004, 19:55
Default Re: Convective Heat Transfer - Heat Exchanger
I doubt your simulation is converged. Some pointers for CHT modelling:
1) Usually the solid timescales are much slower than the fluid timescales. Hence use a solid timescale factor, I often use about 1000. 2) Even though you have 1 to 1 node matching across your solid/fluid interfaces, I recommend specifiying GGI interfaces. I understand they work better than the default 1 to 1 interface. 3) Include balances in your convergence parameters. This is very important in CHT models. 4) Run it for longer! I bet if you look at the balances of this simulation they will not have converged yet.
Old   October 20, 2004, 01:17
Mark
Thanks again!! I will try the points you have posted. The convergence reaches the residual of 10e-5!! But it does look like that there is something wrong. First the convergence is getting "slower" but suddenly it starts going down.
Regards,
Mark
Old   October 20, 2004, 19:51
Hi Mark,
It is common for the residuals to slow convergence as the simulation proceeds. As I said in my previous posting, it is very important to converge on balances or conservation as well as residuals in CHT simulations.
Old   November 1, 2004, 07:57
dauren
Old   November 12, 2004, 22:55
MARCO CORONADO
I'm trying to find the the over all transfer heat coeficien in transicion between laminar flow and turbulent flow in a heat exchanger, and i'd like to know if you could mail me some information, thanks
Old   November 15, 2004, 16:55
Mark
Hi Marco!
The heat transfer coefficient depends on its definition. If you do not know the heat flow you have to calculate it by an energy balance on one side of the heat exchanger (mass flow * heat capacity * (T_in - T_out)). An average heat transfer coefficient can now be derived by using the logarithmic temperature difference (average heat transfer coefficient = heat flow / (area * logarithmic temperature difference))
I hope this is what your question was about?!
A good book is Heat and Mass Transfer by H.D. Baehr and K. Stephan
Help needed in using wall BC for heat transfer analysis of heat exchanger tubes hassaan FLUENT 2 June 25, 2013 08:05
Help with mass transfer in heat and water vapor exchanger mullenc525 CFX 7 January 26, 2011 00:26
UDF for Heat Exchanger model francois louw FLUENT 2 July 16, 2010 03:21
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 23:53
UDF convective heat transfer correlations sarah FLUENT 0 March 29, 2007 10:52
