How to define a gadient boundary inside domain |
October 18, 2004, 15:26 |
Hi, all I want to define a gradient boundary condition inside a domain in CFX4, can some one help me?
thanks |
October 18, 2004, 19:20 |
Re: How to define a gadient boundary inside domain
If you wish to define the temperature/enthalpy gradient you do that using heat fluxes. If you wish to define a velocity gradient you can do that using a wall and defining the shear stress. Glenn Horrocks |
October 19, 2004, 04:31 |
I want to define it for a user scalar, this boundary is only for the scalar, the velocity and all the other transport species are not inflence by the boundary, which means the flow will go through this boundary without any restriction, is this possible in CFX 4? Thax
October 19, 2004, 20:00 |
You can also specify fluxes of scalars at boundaries. You might be able to do what you want with a scalar source term. Can you explain what you are trying to do? Glenn Horrocks |
October 20, 2004, 06:05 |
Thanks, I plan to work this out by user source term. what I want to do is solve a Posssion equation for potential field in a subdomain inside the flow domain. The gradient potential boundary condition inside the domain rather than the flow boundaries. How to do this using user source term?
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
Missing math.h header | Travis | FLUENT | 4 | January 15, 2009 12:48 |
REAL GAS UDF | brian | FLUENT | 6 | September 11, 2006 09:23 |
UDF FOR UNSTEADY TIME STEP | mayur | FLUENT | 3 | August 9, 2006 11:19 |
Please help with flow around car modelling! | Tudor Miron | CFX | 17 | March 19, 2004 20:23 |
