variable composition mixture phase change simulation |
Xuesong Wang
Rep Power: 0 ![]() |
Dear friends
I want to use the CFX to simulate the phase change process in a ammonia/water turbine. Since ammonia/water mixture is a non-azeotropic mixture, its condensation process is a temperature change process. I don't know which phase change model can realize this process. And there is very little information in the CFX help documention. If anyone has done the relevant simulation, could you please give me some advice? Thank you very much. |
multicomponent, multiphase flow |
UDF for modifying density of mixture phase during the calculating process | sola86 | Fluent UDF and Scheme Programming | 2 | May 28, 2019 09:24 |
What are ways to reduce the time taken by fluent and meshing process in phase change. | ~Akshay350~ | FLUENT | 0 | March 23, 2017 12:39 |
variable composition mixture | ranjith | CFX | 3 | October 15, 2010 09:50 |
Variable Composition Mixture vs. Fluid Pair | Abby | CFX | 0 | February 18, 2009 11:00 |
Phase Change Simulation | JoHn@ | Main CFD Forum | 0 | December 19, 2003 18:30 |
