October 12, 2004, 08:05 |
ICEM script problem
Hi all, does anybody have an experience with scripts in ICEMCFD? For the purpose of an optimization loop I have written a script which generate gemetry and grid automaticly. At the end of the script I have to export grid to the FLUENT format. The name of the MSH file should be varying according to a variable.
I have arranged it by these lines: set outfile fluentmesh1 ic_run_application_exec . {} $env(ICEM_ACN)/icemcfd/output-interfaces/georampant {-dom E:/tetra_mesh_auto.uns -b E:/family_boco.fbc E:/$outfile} it gives error message "can't read "outfile":no such variable" but when I try check the variable list $outfile it returns correct result "Result:fluentmesh1" If you have any idea please write it. Thanks Zbynek |
ICEM keyboard problem in linux | gravis | ANSYS Meshing & Geometry | 4 | February 28, 2020 10:23 |
problem with surface creation in ICEM from multiple curves | dialolema | ANSYS Meshing & Geometry | 2 | October 27, 2014 14:14 |
Problem in running ICEM grid in Openfoam | Tarak | OpenFOAM | 6 | September 9, 2011 18:51 |
[ICEM] Automatic mesh generation script surface intersection problem | stuart23 | ANSYS Meshing & Geometry | 0 | May 13, 2011 02:10 |
Problem exporting big meshes from ICEM to Fire | Emil | CFX | 0 | October 10, 2008 14:06 |
