How to use Hexa smoothing function?
Old   October 6, 2004, 00:21
Default How to use Hexa smoothing function?
Nick
Help manual (hexa meshing appendix) did mention about the possibility to improve the hexa mesh by smoothing it in CFX ICEM 5.0.
Just wonder if the technique is the same as the one for tetra smoothing? ie. use the global mesh smoothing under the "edit mesh" and choose Quality as the criteria. There's a function "orthogonal smoothing" beside the "global smoothing". Anyone know what's the difference between these two? Thanks, Nick.
Old   October 6, 2004, 00:42
Default Re: How to use Hexa smoothing function?
Nick
Just found one more question: Does anyone know the difference between criteria "Quality" & "Quality (Version4.3)" under the "smooth mesh globally"? They aren't the same as the values shown in the chart are very different when different criterion is chosen (Quality:min 0.63, Quality Version4.3:min 0.11??? gosh...why so low?)
PS:tried to use the orthogonal mesh smoothing but it ended up with much lower quality than the original non-smooth hexa mesh. Really not sure what's going on there. Anyone know the reason?
Thanks,Nick
Old   October 6, 2004, 00:47
Nick
When I tried to use "smooth mesh globally".... It doesn't work & 0 elements are being smoothed as they're undefined. Anyone know about this error? ICEM5 quits itself with error Signal 6 later whenever I try to use this function (SGI unix platform)
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 05:37
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 01:35
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
