Jackyy
Rep Power: 8 ![]() |
The ANSYS CFX solver exited with return code 1. No results file has been created.
why is it give like that error you think ? |
Rep Power: 144 ![]() ![]() ![]() ![]() |
Many, many things cause this. CFX error messages are renowned for not being very helpful. You have to look at the error in context to work out what it actually means.
Jackyy
more detail.
+--------------------------------------------------------------------+ | Checking for Isolated Fluid Regions | +--------------------------------------------------------------------+ 3 isolated fluid regions were found in domain Default Domain If the isolated regions do not have the pressure level set either by the boundary conditions or using a reference pressure equation, you may encounter severe robustness problems. This situation may have arisen because a domain interface was not properly defined during problem setup. Please carefully check the setup. The solver will stop now and write a results file. The isolated regions can be visualised in CFX Post by making plots of the variable "Isolated Volumes". If you are sure that the pressure level is set in each isolated fluid region then you can force the solver to turn off this check by setting the expert parameter "check isolated regions = f". +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver exited with return code 1. | +--------------------------------------------------------------------+ End of solution stage. |
That error message pretty much explains the problem, doesn't it?
Jackyy
is that error about CFX-Pre ?
Gert-Jan
Rep Power: 27 ![]() |
The error says that you have 3 isolated volumes. You need to go back to pre and make sure you connect them using interfaces. Or, if you don't want/need interfaces, go back to your CAD and make sure you get 1 fluid volume.
Rep Power: 33 ![]() |
Once the ANSYS CFX software stop, you should be able to visualize the "Isolated Volumes" in CFD-Post.
Then, you can see where the domain interfaces are missing if needed at all. |
CFX Solver Manager Error Code 1 | Peta247 | CFX | 3 | June 4, 2016 11:00 |
The ANSYS CFX solver exited with return code 1. No results file has been created | moodkiller | CFX | 7 | May 23, 2016 02:16 |
CFX solver workspace & ourfile Problem | wangy1767 | CFX | 1 | January 9, 2013 09:38 |
CFX SOLVER error !!! | mehrdadeng | CFX | 3 | November 23, 2009 16:42 |
problem in CFX solver about isolated volumes | Yuan | CFX | 2 | August 16, 2004 22:54 |
