September 16, 2018, 16:41 |
CFD post initializing error
Yeasir Mohammad Akib
Rep Power: 9 |
I can't open my CFD post-processing because it is showing an error loading results state. When I am using fluent, sometimes it shows acquiring license but I already have a license. I am adding a screenshot of the problem.
I have another question: How can I delete the loaded file in CFD post? When I am going reload results in CFD post, it's saying this result is loaded over the previous result. |
September 16, 2018, 18:00 |
Gert-Jan
Rep Power: 28 |
Looking at the status of the five steps, yout Fluent calculation has not run yet.
So go to 'Solution', use your RMB and choose to solve the CFD-calulation. Only then you can postprocess the results. |
September 17, 2018, 06:38 |
Rep Power: 9 |
I have not run the full calculation, stopped in the midway after the end of some iteration. The problem is solved for now as I have moved my data to another CFD post-processing option. Don't know what's the main reason for the problem.
Anyway thanks for your reply. |
ansys, cfd post |
Compile calcMassFlowC | aurore | OpenFOAM Programming & Development | 13 | March 23, 2018 08:43 |
Errors in UDF | shashank312 | Fluent UDF and Scheme Programming | 6 | May 30, 2013 21:30 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 10:30 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 18:38 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
