CFX_transient state simulation
Old   September 29, 2004, 11:17
Default CFX_transient state simulation
Aline Luz Salgado
I'm trying to solve a problem of a liquid flow on which an specie is injected. I've already simulated the steady state flow. When I simulate the transient state, the simulation become too slow, because all the equations keep being solved.
Does anybody knows how to simulate the transient state without keeping solving the equations of steady state? I want to run just the additional variable equation with the profile previously calculated and converged.
Old   September 29, 2004, 14:22
Default Re: CFX_transient state simulation
Neyval
Hi Aline,
I am not really sure If I understood what you want to do. I believe that you what to solve a transient problem, which is related to the transport of a tracer species (but the fluid flow is steady state). Since the concentration of the tracer species does not affect the fluid flow velocities, you want to stop the solution of the momentum equations and continue only with the solution of the transport equation for the tracer species. Am I correct ? I am not really sure if you can do that using CFX. If you find out how to do it, please, let me know.
Cheers,
Neyval
Old   September 29, 2004, 19:22
Yes, you can do that. Turn the velocity, pressure (and temperature and turbulence if you have them) off with expert parameters. The expert parameters you are looking for are "solve fluids", "solve energy", "solve turbulence". Then use your previous solution as an initial condition and it should work.
Glenn
Old   October 13, 2004, 08:13
freefish
Glenn ,I think you are right.
Flow-3D for Steady State Simulation CK Main CFD Forum 5 March 2, 2021 07:29
Under-relaxation for steady state simulation in CFX Chander CFX 7 May 1, 2014 13:44
Steady state simulation of a turbine? milos OpenFOAM Running, Solving & CFD 0 November 17, 2009 08:52
steady state, laminar vof_model Garima Chaudhary FLUENT 0 May 24, 2007 04:11
Unsteady state simulation ashish FLUENT 0 February 25, 2007 00:32
