NASA Rotor 37
Old   September 12, 2018, 08:32
Default NASA Rotor 37
Julian121 is on a distinguished road
I am doing a numerical simulation of NASA Rotor 37 for validation.
I used the geometry for Rotor 37 from Turbogrid tutorials and applied a tip clearance of 0.356 mm according to experimental results.
The boundary conditions that I used are as follows:
Inlet: Total Pressure 101325 Pa, Total Temperature 288.15 K
Outlet: Mass Flow at design which is 20.19 kg/s / Number of blades which is 36.
Rotational speed: 17188.7 rpm
According to the tutorial on Rotor 37, the blade row contains 36 blades that revolve about the negative Z-Axis. Does this mean that angular velocity should be -17188.7 rpm or 17188.7?
I am expecting to reach the design pressure ratio which is 2.106, but the outlet pressure becomes less than inlet pressure no matter if I use 17188.7 or -17188.7!
I do not know what I have missed. Can someone please help?
Julian121 is offline   Reply With Quote
Old   September 12, 2018, 09:35
Opaque will become famous soon enough
Based on the axis shown in figure 2, and that Rotor 37 is for a compressor, the value for angular velocity must be negative.
Opaque is offline   Reply With Quote
Old   September 12, 2018, 13:44
I used negative value but still the pressure ratio becomes less than one.
It seems that the blade row acts like a turbine instead of a compressor!
Why does this happen?
Old   September 12, 2018, 17:22
One of the tutorials in CFX is Rotor 37 (see FourierBladeRow tutorial). There is a steady state setup, so you can compare setup
Old   September 13, 2018, 13:26
Thank you. I followed the tutorial. Why sliding mesh was used in this tutorial?
Which one of "Total Pressure" or "Total Pressure in Stationary Frame" expression at outlet should be used to calculate the pressure ratio in the isolated rotor 37?
I think the reason why I was getting smaller outlet total pressure was that I was using total pressure which was based on relative velocity rather than absolute velocity.
NASA Format Stone CFX 3 August 11, 2021 03:16
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 18:00
Error in Two phase (condensation) modeling adilsyyed CFX 15 June 24, 2015 20:42
Segmentation fault in running alternateSteadyReactingFoam,why? NewKid OpenFOAM 18 January 20, 2011 17:55
