Tingyun YIN
Rep Power: 9 ![]() |
Hi, everyone,
I have several questions about the near wall treatment for SST in CFX. As known, automatic near wall treatment uses the blending function between wall function and Low-Re to modify w equation. Here are some questions: 1. When I check the value of solver Y plus, it is different from Y plus. However, in the definition of solver Y plus, as shown in 01.png, it uses the same wall distance of the first wall point. Why it is different when I check the post? 2. Regarding the blend between the analytical expression for w in the logarithmic region, as shown in 02.png, what is the definition of u*? 3. In my case, the geometry is very complicated. Y plus varies from 0 to 50. So, How the automatic near wall treatment works? At higher Y plus areas, wall function dominants. At lower Y plus areas, Low-Re dominants. As shown in 03.png, square root is used with two expressions. I mean the blending function works smoothly. We can't claim only Low-Re works but dominants at low Y plus areas. For example, we cannot claim that when we keep Y plus under 11.06, only the Re-low will work. We can say that Re-low dominants, because the value of w(log) is smaller than w(vis). The more smaller the Y plus, the more effect the Re-low will make. 4. If I understand the Help Document correctly, the wall function used in the blending is the Standard Wall Function? Any comments are appreciated. |
Tingyun YIN
After checking the previous posts in this forum and ANSYS help document, I still don't get any satisfied answers. Any comments?
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 00:04 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Enhanced Wall Treatment | paduchev | FLUENT | 24 | January 8, 2018 11:55 |
OpenFOAM wall function treatment | kimotbwb | OpenFOAM Programming & Development | 7 | March 6, 2015 12:52 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
