Bouyancy Unit Error
Old   September 10, 2018, 15:08
Default Bouyancy Unit Error
Anar Berk
Anar Berk is on a distinguished road
Hello everyone, I am new for Ansys and trying to make an analysis of a rotating blade. After I set up Bouyant Option, the error appears that Invalid units ('dimensionless') set for parameter 'Gravity Y Component' in object '/FLOW:Flow Analysis 1/DOMAIN:Fluid/DOMAIN MODELS/BUOYANCY MODEL'. Expected units: 'm s^-2'. Here is the cll;
FLOW: Flow Analysis 1
DOMAIN: Domain 1
BOUNDARY: Openning
Boundary Type = OPENING
Location = Openning
BOUNDARY CONDITIONS:
FLOW DIRECTION:
Option = Normal to Boundary Condition
END
FLOW REGIME:
Option = Subsonic
END
MASS AND MOMENTUM:
Option = Static Pressure and Direction
Relative Pressure = 1 [atm]
END
MESH MOTION:
Option = Stationary
END
TURBULENCE:
Option = Medium Intensity and Eddy Viscosity Ratio
END
END
END
END
END
COMMAND FILE:
Version = 17.1
END
I don't know what i should do. Could you help me?
Anar Berk is offline   Reply With Quote
Old   September 10, 2018, 15:13
Anar Berk
I have figured out the problem. I had changed the value of 9,81 to 9.81 of Gravity Y Drin. and the error have dissappeared, interesting.
bouyancy, bouyant, gravity
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 08:11
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 03:32
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
