September 21, 2004, 06:36 |
changing settings.pcl file
I was trying to change the settings in settings.pcl using text editor in windows for 5.6, But I am not able to save any changes ! What could be the reason for it? Does anyone have any solution to such a scenario? Do we need to use Perl Script to change the settings file ?
Thanks R P |
September 26, 2004, 12:53 |
Re: changing settings.pcl file
Build updates settings.pcl when it exits. Make sure build is shut down when your do your editing.
Also, settings.pcl is not created automatically in your working directory. You have to create a blank one, and then run build to fill it with the appropriate settings. Shutting down build you can then edit this file and then restart Build to use those settings. Jeff |
September 28, 2004, 08:53 |
Thanks Jeff for your kind inputs. I shall try the said options
R P |
October 15, 2004, 03:55 |
PCL is patran command language, if you want to know it clearly , I suggest you to acknowage it from PATRAN help.
tecio compilation errors in latest 1.6.x | rsamuel | OpenFOAM Bugs | 2 | June 25, 2021 09:10 |
[OpenFOAM.com] OpenFOAM 1.7.1 installation on LINUX UBUNTU 10.10 | electrosin | OpenFOAM Installation | 40 | May 31, 2016 06:11 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 17:02 |
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' | mfiandor | OpenFOAM Installation | 2 | January 25, 2010 10:50 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 02:24 |
