Pedro Oliveira
Rep Power: 8 ![]() |
How can one improve the orthogonality angle of a mesh?
Rep Power: 144 ![]() ![]() ![]() ![]() |
There is no universal answer, it depends on what you are doing. But things which can help include:
* Mesh smoothing * Breaking geometry up into blocks to guide the meshing * Removing unnecessary areas of yukky mesh * Mesh refinement in problem areas * Adjusting inflation settings in problem areas * Changing meshing approach - tets, inflations layers and hexs all are good for different types of mesh * Manually moving problem nodes * ICEM has many tools to remesh problem areas
Pedro Oliveira
Can you name an example of problem areas in pipe flow, and heat transfer problems?
Gert-Jan
Rep Power: 27 ![]() |
I can think of many problem areas but it makes no sense to post common grid problem with the risk that they just do not fit your problem.
If you have a specific problem, you should ask a specific question....... |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Mesh angle and aspect ratio | selvam2487 | CFX | 1 | August 8, 2013 19:06 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
Use mesh motion to introduce angle for static simulation | dancfd | OpenFOAM Running, Solving & CFD | 1 | November 18, 2010 19:15 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
