CFX Averaged quantity
Old   August 30, 2018, 06:37
Default CFX Averaged quantity
AS_Aero is on a distinguished road
Hi All
I am running a URANS computation and I am wondering how can I get the averaged quantity of the variables that is of my interest including the expressions I have used. ? I can only get instantaneous results. But if I want to see the velocity averaged results and plot the contour for some timesteps or average over time, how can I achieve that ?
I found the way using Output Control-->Trn Stats--> Arithmetic Avg--Output variables.-.
But here the available variables are limited and I cant get them for the expressions that I have given.
Kindly help me with this !!
AS_Aero is offline   Reply With Quote
Old   August 30, 2018, 11:05
Gert-Jan
Gert-Jan will become famous soon enough
I think you should assign your expressions to some additional variables in Pre. Then I think you can generate some transient statistics on these additional variables.
Gert-Jan is offline   Reply With Quote
Old   August 30, 2018, 18:08
Opaque will become famous soon enough
Would you mind describing the issue a bit further?
Here is what I understood (feel free to correct me).
You have your own expressions, say
LIBRARY:
CEL:
EXPRESSIONS:
MyExpr1 = Velocity u * whatever - something else
END
END
END
Now you would like to see/plot the Transient Average of say MyExpr1. Then, you create an Additional Variable (Insert), say MyExpr1AV
LIBRARY:
ADDITIONAL VARIABLE: MyExpr1AV
Option = Definition
Variable Type = Unspecified
Units = <correct units as you expect out of MyExpr1>
Tensor Type = SCALAR
END
END
So far, so good, correct? Then, you activate/associate the AV to the domain where you want such expression to be valid. Say Domain 1. Then, edit Domain 1, goto Fluid/Solid Models, activate MyExpr1AV, select Algebraic Equation, and set it as
Additional Variable Value = MyExpr1
Apply the panel, and repeat for all domains you want this to propagate to.
Now visit your OutputControl panel, and MyExpr1AV should be listed for transient statistics. I am sure you can continue from here.
Hope I understood your question correctly. Good luck
Opaque is offline   Reply With Quote
How to get volume averaged quantity of a simulation cptlddd OpenFOAM 1 October 11, 2017 05:40
Modify SST kw model in CFX Tingyun YIN CFX 6 May 12, 2017 07:44
Time Averaged Solution from CFX for Transient Data AS_Aero CFX 6 April 13, 2017 05:51
depth averaged velocity from a CFX free surface flow bolus13 EnSight 8 November 21, 2016 11:22
time averaged results as initial conditions in CFX mike CFX 8 May 7, 2007 15:54
