YPLUS IN CFX5.7-Draft Tube
Old   August 28, 2004, 01:13
Default YPLUS IN CFX5.7-Draft Tube
KKA
hi guys
I am doing some runs on draft tube using CFX5.7. The orientation of the geometry is such that the Z-axis is perpendiclar to the draft tube inlet, and the y-axis is in the direction of the elbow and the outlet. the spanwise direction which is the width is the x-axis.
Now, when I extracted my YPLUS values, they're in thousands. But I knew that my first node on the wall shdn't give me that value after I compute it from the wall shear stress. I don't know if CFX is taken the coresponding original y values realative to the origin or the the normal distance to the wall at respective wall.
Can somebody help me out. if you need more explaination, please do email me.
Thanks a lot
Old   August 28, 2004, 13:55
Default Re: YPLUS IN CFX5.7-Draft Tube
Guy
KKA,
CFX will return the value based on the normal distance from the wall. Two variables are output, Yplus and Solver Yplus. Yplus is calculated in the standard sense, based on the distance to the first node. "Solver Yplus" is what is actually used by the turbulence model (considering the scalable wall functions).
There isn't much room for error in the CFX calculation, so I would check yours.
Guy
Old   August 28, 2004, 17:22
KKA
okay thanks. I'll give it a shot again.
Regards!!
HLL Riemann Shock Tube Matlab Problem Luke F Main CFD Forum 2 May 20, 2016 03:10
Tube inside a tube simulation Rashmichem Main CFD Forum 0 December 14, 2010 02:52
which yplus (SST) sanchezz CFX 17 January 11, 2010 05:45
Draft tube and MFR/SG nyatoto CFX 0 June 3, 2003 06:55
heat transfer coefficients with "bad" yplus Andrew Main CFD Forum 4 April 8, 1999 05:43
