monitoring variables in a transient simulation
Old   August 27, 2004, 23:57
Default monitoring variables in a transient simulation
Craig Johansen
I am modelling the decay of isotropic homogeneous turbulence in a cubic domain with boundary conditions using LES. I would like to save the velocity correlations (all of them uu, uv, uw, vv, vw, ww) at a single node at the center of the domain at EVERY TIME STEP. I need to export these values as a text file.
I want a text file with 7 columns of data at point (0, 0, 0), which is the center of my domain:
Column 1: time Column 2: uu Column 3: uv Column 4: uw Column 5: vv Column 6: vw Column 7: ww
Can CFX do this?
Thanks,
Craig
Old   August 29, 2004, 20:36
Default Re: monitoring variables in a transient simulation
Yes, CFX can do that.
Glenn
Old   August 30, 2004, 14:05
Craig Johansen
This is done through the Monitor output controls, right?
What if I want to save a plane of data at different times? In the monitor options, I can only select a single point.
How do you save a plane of data at different times?
I do not want to use transient results because then I have to manually go to each transient file and save each plane of data.
Thanks
Old   August 30, 2004, 19:00
Hi Craig,
1) The easiest way to output data from a single point is using monitor points. You can extract data from these points as the simulation progresses (or is finished) using the solver manager.
2) For a plane of data, you can either generate a number of monitor points;
2a) or if you want an average over the plane you have two choices: 1) generate transient results files and generate the plane data in CFX-Post (this is the best option generally), or 2) place an interface or subdomain in the region of interest and use a monitor point with an average average/volume average function. This involves generating a new mesh.
3) You cannot save a plane of data at different times in the solution.
4) You do not have to manually go through each transient result file to get the plane data. You can write a CFX-Post script and it will zip through them all.
Glenn
Old   September 4, 2004, 07:58
Sigve
Note that exporting monitor points to a text file also includes innerloop values for each time step.
This is useless information and should be removed from CFX 5.7.
Old   October 6, 2004, 09:10
Aline Luz Salgado
Hi Glenn,
Could you explain me how can I write a CFX-Post script?
problem with journal-file in transient simulation stimpy FLUENT 2 January 4, 2013 00:16
Resume Transient simulation HMR CFX 1 June 28, 2011 22:13
execute udf in ss & transient simulation hosseinhgf FLUENT 0 December 1, 2010 09:41
How to conduct transient LES simulation tianrenshui311 FLUENT 0 November 15, 2010 14:21
Rigid Body State Variables in Solid Immersed Simulation Hamidreza CFX 1 October 19, 2009 07:14
