Edit Run in Progress:CFX5.7-Command Lang. Editor |
August 23, 2004, 15:15 |
Hi guys
I can't save my .def using the Edit in the Solver Monitor or Edit Run in Progress in the Solver Monitor. As as click on file and then Exit, there is always a pop up read as: The CFX Command Editor aborted with error code 2 while editing the ff file ......(then gives the path of my .def) An error has occured in cfx5control The CFX command language Editor was interrupted by signal SEGV(11) Do any body has idea on this. Because it's very irritating since at times I just only need to change the Residual value from 10E-4 to 10E-6 and I have to restart the whole CFX5pre. Please somebody should me out. Thanks a lot! |
First Parallel Run - need some help | Gian Maria | OpenFOAM | 3 | June 17, 2011 13:08 |
Help-Edit Run in Progress | BalanceChen | CFX | 0 | March 30, 2011 10:23 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 21:02 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 12:46 |
Cycling a transient run | Chetan Mistry | Phoenics | 0 | March 3, 2004 10:50 |
