how to recover trn files after crash?
Old   August 23, 2004, 06:28
Default how to recover trn files after crash?
pi
Hello everybody, my problem arises after the host crashed during a long transient simulation before to complete it. I set backups with an interval of 100 iterations (about 1 day) and just a few variables in the most often trn files. The thing is that the last backup occured quite before the crash so I have many trn files after it. For example: my last backup is 600_full.bak and there are trn's since then up to 689.trn. Iīd like to post these last 89 timesteps data too. When I try to load them from post it is impossible to open them unless a bak or res file is written after the last trn.
Is there any trick or roundabout to visualize those trn?
Thanks you
pi
Old   August 24, 2004, 01:35
Default Re: how to recover trn files after crash?
deLuther
You can postprocess result by joining .def file with .trn like for partition files. i.e. On UNIX systems: cat filename.def *.trn > newfilename.res On Windows systems type: copy /b filename.def + *.trn newfilename.res where *.trn is your .trn file. You only can do it for one .trn file per time. i.e. for each .trn file you need to create it`s own .res file and postprocess by one unlike with normal result file.
Old   August 24, 2004, 05:20
pi
Hi deLuther, I donīt know if this way is practical for many files but perhaps it might be useful in the future. Thanks for the answer.
pi
Old   August 25, 2004, 01:20
deLuther
Hi pi, I also think that this way is not very practical but sometimes to see solution after crash it can be the only way. At least you can restart from such file, of course if file contain essential variables to restart run.
deLuther
Old   August 25, 2004, 06:45
jasper
Hi Pi,
You can also cheat post by copying a .res file from a different run that went beyond the number of timesteps of the run that crashed. Having read this results file into post you can then load all timesteps up to the crash.
The .res file from transient runs provides a framework for the reduced .trn files to be read and apparently keeps track of the numbers of these .trn files. It would be convenient to be able to modify the .res file in that respect, but it is coded.
Cheers,
Jasper.
UDF issue MASOUD Fluent UDF and Scheme Programming 14 December 6, 2012 14:39
CFX crash recovery, is there a way to merge mon and trn files? jrl4444 CFX 1 October 30, 2010 12:52
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 04:01
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
