Memory Problem
Old   August 21, 2004, 07:47
Default Memory Problem
sola
Hello All, I understand from some postings in this site that it takes about 400MB to solve approx. 1million volume mesh. I have a simultion that is running across 3 computers with a memory ratio of 2,3,2 Gb and nothing else is running. The mesh breakdown is thus : Total number of Elements =9.62 Ml
Tet =7.67 Ml
Prism =1.95 Ml to my amazement and frustration, it is taken 6.05Gb to carry on the simulation, what gives here ? I only expected to use 4.5Gb. I will appreciate any explanation, since I have more models built around the computers that I have.
Old   August 21, 2004, 22:55
Default Re: Memory Problem
HK
How did you divide the load?
Old   August 22, 2004, 10:38
sola
Automatic partitioning.
combustion problem mcnair CFX 9 March 22, 2011 15:06
Fluent Parallel Memory Usage David Christopher FLUENT 1 March 3, 2011 03:20
RAM memory problem alpha Main CFD Forum 8 February 12, 2008 12:07
memory problem Matt FLUENT 1 October 1, 2006 19:24
"Memory too low" problem with Fluent HELP NEEDED Amr FLUENT 6 May 8, 2006 13:06
