August 15, 2018, 05:04 |
CFX-CEL problem
zhubohong
Rep Power: 8 |
Hi, everyone. Recently, I tried to use the CFX-CEL tool to modify the material property. The modified equation involves the integral equation, as shown in the following figure. Dose someone know what is the function symbol of intergration in CFX-CEL?
August 15, 2018, 11:51 |
Rep Power: 33 |
Would you mind describing in more detail?
There is no integral in the figure shown. |
August 16, 2018, 05:49 |
#3 | |
zhubohong
Rep Power: 8 |
It means I don't use the energy equation to model it, just predict it by modifying the material property of gas phase. As shown in Fig., the temperature change of gas phase is a function of the time that gas phase contacts with liquid phase. This is a intergral equation. Therefore, my question is what is symbol of intergration in CFX-CEL. Just like, in CFX-CEL, the symbol of multiplication is *, the symbol of exponentiation is ^, etc. |
August 16, 2018, 06:27 |
Rep Power: 144 |
CEL has no integral function like you describe. It has some line, area and volume integral functions - see the CFX documentation reference guide for that.
Also - rather than trying to make your own model to get the temperature why not consider the built in lagrangian temperature model? Again, have a look at the documentation to see if the built in temperature model will do what you want.
August 16, 2018, 07:32 |
#5 | |
zhubohong
Rep Power: 8 |
August 16, 2018, 08:42 |
Rep Power: 144 |
That is not what I said at all.
First of all, there already is a model for temperature in CFX. You should look at this model to see if it does what you want. You don't need to make your own model for it. And if that does not work then you can probably do it using additional variables. But I am hopeful the built in temperature model will work for you, so look at that first.
August 17, 2018, 00:08 |
#7 | |
zhubohong
Rep Power: 8 |
As I said that before, if the density property of gas phase is a function of e, I can't directly modify the gas property using this equation. This is because the flow field is not calculated, and the value of e cannot be fed back. As you said, if I use a additional variable to read the value of e and change the equation, which is a fucntion of additional variable, to describe the density of gas phase, can this way work? |
August 17, 2018, 00:19 |
Rep Power: 144 |
I have just checked the Lagrangian model and I think the temperature model built in will do what you are looking for.
Alternately, you may be able to model this with a Eularian model and I think you will also be able to model the effects you are talking about there as well. You should not build your own model for something which looks like it is already in the software. If the built in models are not suitable please explain why they are not suitable.
Convergence problem of CFX when comparing with FLUENT with same mesh | guxin7005 | CFX | 8 | May 22, 2014 15:13 |
cfx mesh problem... | mactech001 | ANSYS Meshing & Geometry | 0 | November 5, 2009 02:19 |
Workbench (CFX) bucket problem | njsavage | ANSYS | 0 | April 29, 2009 17:10 |
Urgent Problem with Hypermesh and CFX | Luk | CFX | 5 | March 14, 2008 04:59 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 04:07 |
