SETWRK & GETWRK (CFX4)
Old   August 2, 2004, 14:45
Default SETWRK & GETWRK (CFX4)
RK
Dear Someone:
I have calculated a new density value in USRDEN. Now, I would like to use the calculated DENN from USRDEN in USRCND. This is what I have been recommended to implement: put the values in user work space in USRDEN & then use it in USRCND. But the way I have done using SETWRK in USRDEN and GETWRK in USRCND does not do the job. Can anyone suggest anything?
Thanks in advance.
RK
Old   August 5, 2004, 11:34
Default Re: SETWRK & GETWRK (CFX4)
Dougal McQueen
Use USRWRK to set the work spacre for the variable. Then GETWRK to find the pointer to where the memory has been allocated, and either set or call the variable from that position in the stack.
CFX4 dump file format Glenn Horrocks CFX 2 October 12, 2003 20:16
remote user of CFX4 John CFX 5 September 7, 2003 19:20
how can I get the granular temperature in cfx4? danney CFX 0 September 3, 2003 00:06
OpenDX with CFX4 Brett Towler CFX 0 December 3, 2001 18:31
CFX4 Validation Glenn Horrocks CFX 0 January 30, 2001 23:56
