CAD2Mesh query
Old   July 28, 2004, 12:17
Default CAD2Mesh query
Prash
Hi
We are working on a complex arterial geometry in the retina and we are stuck at the junctions. We constructed the three dimensional basic network of arteries using another CAD program and we could successfully import that into CAD2Mesh. However, we noticed that some solid bodies appeared as hollow surface bodies (mainly at the junctions of the arteries). We are unable to mesh the stuff and think that this might be due to those surface bodies. Could anyone suggest a way to get pass this problem? Are we right to think that it is these surface bodies that are causing the problem and if so, is it possible to convert them to solid bodies?
Cheers, Prash
Old   July 29, 2004, 10:24
Default Re: CAD2Mesh query
Derrek
Prash:
You can attempt to form solids (body operation) in Design Modeler. Solids are required for CFX MESH. However, if you have a license of ICEM through CAD2MESH, you can use TETRA to mesh the model. TETRA only requires bounding surfaces.
Cheers,
Derrek
Old   July 29, 2004, 10:35
Prash
Many thanks, Derrek! We used ICEM to generate a tet-mesh that seems to work without probs with CFX-5.7.
Cheers, Prash
Old   August 1, 2004, 19:26
tuki72@hotmail.com
i thought icem needs a cloded set of surfaces as well?
how to query node coordinates? phsieh2005 OpenFOAM Post-Processing 3 November 26, 2018 21:13
How to install CAD2Mesh? Jason CFX 4 July 12, 2004 11:58
CAD2Mesh geometry creation hannah CFX 4 May 17, 2004 13:17
CAD2mesh spacings pi CFX 0 May 14, 2004 15:31
CAD2Mesh infl. exp factor bogesz CFX 2 April 4, 2004 19:50
