August 11, 2018, 05:03 |
Torque Calculation + MRF
Sasan Ghomi
Rep Power: 15 |
Dear friends,
These days, I am using MRF method so as to simulate the fluid flow around a rotor of an electrical generator. In fact, the flow is rotating around the rotor surface (because of the rotational velocity of Rotor (3000 RPM)) and also, there are some fluid flows whose directions are perpendicular to the rotor axis. The problem is that when I measure torques (In CFDPost software) on the interface of rotating domain, there are different torques on the two coincident interfaces. (The interfaces belong to stationary and rotating domains respectively) Do you think that it is showing that the simulation has not been done correctly? I personally suppose that we must have the same torques on the coincident interfaces. I would be grateful if you could clarify this issue. Best Regards Sasan Ghomi |
August 12, 2018, 06:45 |
Rep Power: 144 |
Calculating the torque on a fluid to fluid interface is not meaningful. There is nothing in an interface for the force to act on. Forces act on walls, and in some cases inlet/outlets.
Torque calculation of 2D VAWT Wind Turbine | Anonymized_JL1 | FLUENT | 14 | September 26, 2013 03:35 |
Strange torque calculation | danny123 | OpenFOAM Running, Solving & CFD | 5 | May 7, 2013 04:59 |
MRF and Heat transfer calculation | Susan YU | FLUENT | 0 | June 2, 2010 08:46 |
Torque calculation in pumping equipment | Kirill | Main CFD Forum | 0 | June 26, 2007 16:59 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
