July 22, 2004, 05:03 |
constant volume combustion
hi all
i've to simulate turbulent premixed combustion in a constant volume bomb(cube)& to record pressure time history the bomb is filled with fuel-air mix & then all valves are closed the turbulence is created by moving a perforated plate inside the cube the mix is ignited at center by a spark the problem is there is no inlet outlet so no inlet or outlet bc is there only bc is wall bc problem is(i)can i use edm for this (ii)i,ve defined high temp on some elements in center but combustion is not taking place please help me in urgent thanx |
March 22, 2011, 15:23 |
Iltesham
Rep Power: 15 |
Hi Vaibhav.
I am trying to do very similar simulation now. I shall be ever grateful to you if you could let me know what steps did you follow for combustion in the closed chamber? I am trying to ignite the fuel using high temperature patch but not working. Also i tried the spark model but still not working. can you please help me here. I will greatly appreciate. |
March 23, 2011, 15:43 |
Rep Power: 17 |
The simulation is done by your workstation. You have to model. In other words you have to assemble equations which give you a model of the physical reality. If you use a code, which has all these things already in, you should at least check what the code does.
Without loss of generality have a look at http://www.cfd-online.com/Wiki/Combu...Break-Up_model . Do you see temperature in the chemical source term for turbulent combustion? No, it does not feel. There is also no enthalpy. That's the reason why many combustion models can not be ignited by temperature initialization or heat release.
- - - - - ------------------------------------------------------------------------ Please do not forget: I am not paid for answering your questions. Thousands of issues can cause a division by zero. Please do not capture a thread, with the argument: "I have the same issue ...." |
March 26, 2011, 10:23 |
#4 | |
Iltesham
Rep Power: 15 |
Please look at this paper, They have done exactly what i want to do and they have used a spark to ignite the fuel in side the combustion chamber. http://www.sciencedirect.com/science...9&searchtype=a |
March 26, 2011, 14:03 |
Rep Power: 17 |
The last two years I spent more time on fan blades then on combustion. So I did not look into 13.0. I do not know if there is a new feature which solves your problem. For 12.1 the situation was as follows:
Regards, Joey PS: Do you really expect me to pay 31,90 $ and two hours in order to understand what you intend to do?
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 18:44 |
blockMesh error ... | balkrishna | OpenFOAM Pre-Processing | 0 | August 17, 2010 02:39 |
[Commercial meshers] CuBit | t42 | OpenFOAM Meshing & Mesh Conversion | 6 | July 10, 2008 07:51 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
