I want to compare result between runs with different meshes and different settings. What tricks are there to do this? When I used FLOTRAN I did this by creating a results file that was the difference between two runs (either percentage difference or absolute). Can something similar be done with CFX?
Mark |
Use the interpolation function in Solver Manager between the two .res files.
This will create a .res file which has the difference between the two files. (mkae a copy of the two .res files first to avoid over-writing). |
Thanks Jon, I hadn't realised that interpolation could calculate the difference.
Mark |
Is this understanding of turbulence models correct? | 3kha | Main CFD Forum | 3 | January 31, 2011 21:31 |
Exporting Fluent results as 4D images in an interactive window | Luca95314 | ANSYS | 0 | October 11, 2010 17:16 |
Fluent 12.1 - transition viscous models | kdrbrk | FLUENT | 4 | July 29, 2010 11:34 |
Bad results when compared with Wind Tunnel | Luiz | FLUENT | 1 | October 23, 2006 02:30 |
Are combustion models actually any use? | None given | Main CFD Forum | 22 | September 24, 2005 11:37 |
