August 7, 2018, 09:08 |
some problems in CFD simulation with CFX
Hamda
Rep Power: 8 |
I am supposed to model heat transfer between spheres (solid) and fluid (the space) and I have a few questions related to the simulation. I will really appreciate if someone who did the same simulation before helps me on this issue. My problem is related to interface and boundary condition and I couldn't run. Many thanks |
August 7, 2018, 09:55 |
Erik
Rep Power: 23 |
Most of us here could help you. I doubt it's common to have run the same simulation as you. I haven't, and wouldn't, as I would have used symmetry, (up to 1/8th) with perhaps periodic translation in the Y direction. So my model may have been about 32x smaller.
August 7, 2018, 15:56 |
Hamda
Rep Power: 8 |
I said "same" not "exactly". I know that most members want to help but you know sometimes a wrong advice causes wasting time. my account is new but I am not a new member. Once this site was very helpful to me and so many things about fluent I have learned from this site, since when I asked a question, those members who had the same experience answered and shared their precious ideas.
By the way, I solved my problem. Kind Regards Hamda |
August 8, 2018, 03:13 |
Maxim
Rep Power: 13 |
Dear Hamda,
would you please explain the solution to your problem in case some other user will run into the same problem in the future? Thank you |
August 8, 2018, 09:57 |
#5 | |
Bruno
Rep Power: 21 |
As you mentioned, the experience you gained might be helpful to someone else searching the forum in the future. Cheers |
boundary condition, cfx, heat transfer, spheres |
Why cores number in CFD simulation is preferred to be integer multiple of 4 for CFX? | Pierre1 | CFX | 4 | March 23, 2015 20:20 |
CFD Online Celebrates 20 Years Online | jola | Site News & Announcements | 22 | January 31, 2015 01:30 |
[ICEM] Simple pipe meshing - problems with y+ in CFX | Keizers | ANSYS Meshing & Geometry | 23 | January 15, 2015 09:00 |
Possibilities to influence Simulation in CFX | biro | CFX | 37 | November 26, 2014 06:02 |
Boundary condition setting regarding turbine simulation using CFX | Lacerlacer | CFX | 11 | March 12, 2012 10:32 |
