July 13, 2004, 08:26 |
IGES files in CAD2Mesh
Hi
Could someone suggest me the best possible way to import IGES files (generated by erstwhile Build 4.4) to CAD2Mesh? Cheers, Prash |
July 13, 2004, 15:50 |
Re: IGES files in CAD2Mesh
Open Design Modeler (via ANSYS Workbench). You have access to this via your CAD2MESH license. Go to File->Import Geometry File-> browse for your IGES file.
Regards, Derrek |
July 14, 2004, 05:51 |
Many thanks Derrek for the prompt reply!
We have infact done this but the machine simply slips into a 'thinking' mode and never gets back. Are we missing out something here? Cheers, Prash |
July 14, 2004, 10:02 |
IGES comes in many flavors, do you have any choices in the version of IGES to export? Also, how big is the IGES file? I have seen cases where the IGES file is very large and takes awhile to import. How long do you wait to allow the computer to "think"?
Derrek |
July 14, 2004, 10:41 |
Hi again Derrek,
I waited for two hours. I also guessed that it might be the size which a little more than 25MB ... I am in the process of reducing it by removing surfaces etc from the IGES file ... Cheers, Prash |
July 19, 2004, 05:17 |
You can check your IGES file by viewing the file in the program Acitfy SpinfirePro 2004 to see whether the exported file is correct or not. You can download a trial at http://www.actify.com/v2/products/SF...onal/index.htm
UDF issue | MASOUD | Fluent UDF and Scheme Programming | 14 | December 6, 2012 14:39 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 04:01 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 14:43 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 08:21 |
OpenFOAM15 paraFoam bug | koen | OpenFOAM Bugs | 19 | June 30, 2009 11:46 |
