Mr. Stuart
Rep Power: 8 ![]() |
Hello all.
I am relatively new to the CFX software. I was wondering I am attempting to run a simulation with a rotating fan. I've tried simply putting the total fan geometry in a enclosure and setting it up a solid rotating domain in a fluid domain. No such luck. I'm pretty green, please don't forget that. I am running it coupled with ansys 15. Thanks, Mr. Stu |
Rep Power: 144 ![]() ![]() ![]() ![]() |
It sounds like you are modelling the rotor as a solid domain. That is not correct. Please look at the CFX tutorial examples on rotating machinery as that will show you how to do it.
Mr. Stuart
Thanks a ton. Any one of the tutorials do you suggest? I don't have access to the turbo interface, I don't think.
Would immersed solid be more appropriate? This isn't anything like I remember from COMSOL. Lol |
Any of the rotating machinery tutorials.
No, not immersed solids either ![]()
Mr. Stuart
Haha! Alrighty that's what I'll do.
Mr. Stuart
Alrighty, so I looked at a few of tutorials and took up the good fight once again!
Now, I have another issue: isolated fluid regions. Here's the scenario: I have placed my fan geometry inside a cylinder to outline it's rotational geometry, and placed that inside of a bigger cylinder ! I also cut 3/4 of it off for resource management. Alright, so, if the fan geometry is the crème in this oreo cookie, I have set up two frozen rotors for both of the chocolate cookies and the big encapsulating cylinder. Now, I am having issues with the crème to air interface. Any suggestions? I am using an opening boundary condition by the way. I have set the "fan" domain (fan geometry + fan blade span revolved) to rotate. Thanks a lot! Mr. Stu |
As much as visualising oreo creme layers is useful an image would be better
![]() The isolated fluid regions error means one or more of your interfaces are not connecting. You better check your interfaces. Also post some images of what you are modelling and the output file.
Mr. Stuart
Thanks again for your help.
I am really unable to share any photos at this point. :/ I have tried simplifying it once again; created a cylindrical enclosure of my fan, and subtracted the fan while preserving the tool body. Set up the fan as its own fluid domain and assigned wall boundary conditions to surfaces, and of course made the enclosure a fluid domain. Thanks in advance. |
cfx |
How to build current blower fan model in Flotherm | eric0722 | FloEFD, FloWorks & FloTHERM | 3 | January 2, 2021 02:36 |
Simulate rotating Fan using no MRF | federernadal | Main CFD Forum | 2 | May 3, 2018 00:11 |
Car external aerodynamic with wheel spinning issue | hokhay | FloEFD, FloWorks & FloTHERM | 2 | August 18, 2016 04:23 |
Interpreting streamlines of a rotating fan. | danbence | Visualization & Post-Processing | 1 | April 8, 2014 10:13 |
axial flow in counter rotating ducted fan | Vishu | FLUENT | 4 | January 13, 2004 17:52 |
