July 26, 2018, 08:07 |
Autoignition delay time for kerosene
Alex
Rep Power: 8 |
Hello. I need some empirical correlation for calculation knock in kerosene-air mixture to get autoignition delay time. (A general case is needed, not only for piston engines.) Can you advise me something?
Douaud and Eyzat correlation is determined for 80<octane number<100. Of course, I can try to make CEL-analogue for ON 38-40 (equivalent of octane number of kerosene), but I dont think, that this is good idea. |
July 26, 2018, 21:03 |
Rep Power: 144 |
This is specialised question on IC engine modelling, not a CFD question. You will need to do your own research in the literature to work that out.
correlation, ignition delay time, kerosene, knock |
bash script for pseudo-parallel usage of reconstructPar | kwardle | OpenFOAM Post-Processing | 42 | May 8, 2024 00:17 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 03:20 |
Help for the small implementation in turbulence model | shipman | OpenFOAM Programming & Development | 25 | March 19, 2014 11:08 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 10:34 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 05:03 |
