Difference between homogeneous and in-homogeneous free surface model.
Old   July 25, 2018, 05:11
Default Difference between homogeneous and in-homogeneous free surface model.
Taiwan,new north city
Rajaero is on a distinguished road
Dear all,
I am working on a multi phase problem of oil/air separation by gravity. this phenomena used in oil injected compressor tank (horizontal tank). i tried to solve this problem by (volume of fluid and homogeneous and in-homogeneous free surface model approach). please clarify the following questions.
Boundary condition:
Domain : air domain and oil domain
Interface : one fluid-fluid interface
Inlet : air/oil mixture
Outlet 1 : air outlet (opening pressure condition)
Outlet 2 : oil outlet (opening pressure condition)
Questions:
1. I am confusing with homogeneous and in-homogeneous free surface model.which model to select?
2. Homogeneous and in-homogeneous model results are different with the same boundary conditions and mesh.
3. solution is not converging
Thanks in advance...
Rajaero is offline   Reply With Quote
Old   August 1, 2018, 04:27
Thomas
Meister is on a distinguished road
Questions:
It is well described in the CFX Theory Guide
I assume your solution is not converged, I wouldn't invest much time in comparing
Try to change the numerical setup between segregated and coupled, if air is compressible use incompressible setup first
Meister is offline   Reply With Quote
Old   August 1, 2018, 06:09
Thanks Thomas,
i have changed a numerical setup from segregated to coupled as per your suggestion.
